1957 Grille mount brackets - NCRS Discussion Boards
  • Jean P.
    • November 22, 2010
    • 16
    I'm looking for some advise on how are tighten the grille mount brackets on the car ?
    The nuts is exactly the size of the groove of the bracket and I'm not able to turn them to tighten them ?
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 1957 Grille mount brackets
    does your question involve the grill surround or the horizontal bar that bolts to the oval or the teeth fastening to the hoirizontal bar? mike
    • Jean P.
      • November 22, 2010
      • 16
      The question involve the 5 black vertical grill mount brackets that bolts to the oval. on the upper and lower part of the oval.
      Should I use washers to prevent the bolt to get in the groove ? that does not sound right to me ...
      (I can post picture if needed)
      • Jean P.
        • November 22, 2010
        • 16
        This is a picture from "inside the grill".
        The nuts get and the bar groove and prevent to be tighten.
        • David S.
          • December 1, 1982
          • 310
          Hi Jean,
          What you need is to first install a flat washer and then your nut. I am attaching a picture of what I am talking about.
          Hope this helps
          Dave
          • Jean P.
            • November 22, 2010
            • 16
            Got it ! I was not sure ... but you confirm what I need to do.
            Thanks a lot.
