Turn signal switch hub - NCRS Discussion Boards
  • Peter V.
    • June 2, 2008
    • 116
    The hub surrounding my turn signal assembly on the column is loose. It appears to be held securely by a single screw on the back left of the hub. I can't tighten it because the instrument panel is directly behind it.
    Looks like the steering shaft needs to be lowered a bit to tighten the screw.
    Am I on the right track?
  • Dennis C.
    • June 30, 2002
    • 887
    Re: Turn signal switch hub
    Peter,
    The screw tightens a wedge within the hub. Try removing the bottom cover of the lower dash cluster. Then using a thin relatively short blade screw driver, with the handle in the void of the removed cover, try to work the screw.
    I have been able to work this screw without chipping the hub or dash cluster using this method. I also install some painters tape on the hub and the dash cluster just in case.
    Dennis
    • Peter V.
      • June 2, 2008
      • 116
      Thanks, Dennis. I'll give it a try!
        It also simplifies future maintenance if you replace the original wedge screw with an allen-head screw.
        • Peter V.
          • June 2, 2008
          • 116
          Dennis and John,
          There's so little room I couldn't even get a modified, severe right-angle screwdriver in there after removing the lower cluster cover.
          It appears that loosening the steering column enough to just move it down a half inch or so is the only way to get at that screw. I'm about to tackle that next. Any secrets to making that job easier? THANKS!!
