Tires - NCRS Discussion Boards
Tires
  • W K.
    • December 16, 2009
    • 61
    Tires
    I'm looking for "service replacement tires" radial construction for my 66 by an OEM manufacturer with correct 5/8" whitewall. Do they exist? I appreciate help!
  • Terry B.
    • August 31, 1999
    • 607
    Re: Tires
    You should check out Kelsey tire at http://www.kelseytire.com/home.html
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Ron N.
      • August 18, 2008
      • 243
      Re: Tires
      Discount Tire still sells the Goodyear Integrity. It's a radial currently available in B/W, also made in 5/8" W/W but you would D/T to find them for you. They found a set of 4 in November '10 from a store in Ohio (I'm in TX). The W/W sells for $90.
      Ron
      • John D.
        • June 30, 1991
        • 875
        Re: Tires
        The Firestone FR380 was another choice I'm not sure if it's still available in whitewall or not.....
        • W K.
          • December 16, 2009
          • 61
          Re: Tires
          Thanks, so far all I have found is from Diamond Back, expensive as you know. Kelsey Tires does not sell them in a radial.
          • W K.
            • December 16, 2009
            • 61
            Re: Tires
            Ron
            So you are happy with those tires?
            • W K.
              • December 16, 2009
              • 61
              Re: Tires
              has anyone used, bought the BFG Radial T/A or Firestone Brand from Diamond Back? Were you satisfied, happy with your purchase? I don't mind spending the extra money if it is a good product.
              • Jim D.
                • 2884
                Re: Tires
                Ron
                The good news - they are a great tire. I have them on my 65.
                The bad news - according to the Goodyear dealer, the whitewall Integrity has been discontinued. You might be able to find some leftovers if you hurry.
                • John C.
                  • January 1, 2005
                  • 616
                  Re: Tires
                  I have the Diamond Back Firestone FR380's on both my 67 and 69. They have been excellent tires.
                  John
                  • Daniel N.
                    • June 20, 2010
                    • 33
                    Re: Tires
                    Yes, they are available with white walls. (I just bought a set, from Sears.) In fact, I think that's the only way they come now. However, the white walls are not the correct width and will not get any judging points, even though Firestone was an OEM for white walls. Diamond Back will modify the FR380s so that the width is correct, but the cost goes up by about $500 for a set. Diamond Back has other alternatives as well, such as Michelins that they modify.
                    • Jack M.
                      • March 1, 1991
                      • 1146
                      Re: Tires
                      I purchased their Firestone Supreme (retaining the lettering) back in the summer of 2008 for my '66...I'm a very satisfied customer.
                      Jack
                      • Ron N.
                        • August 18, 2008
                        • 243
                        Re: Tires
                        Firestone has 3 current day radial tires in w/w and in correct size for a '66 or '67:
                        FR 380 (good)
                        FR 710 (better)
                        Affinity Touring (best)
                        All come in w/w but the width is not 5/8". I measured it at about 6/8".
                        As I said in my previous post the Goodyear Integrity is your best bet for reasonable money. It's a NOS brand and the w/w is 5/8". They are out there but the tire dealer will need to search for them. And make sure the DOT date is not too old if you intend to drive on them regularly.
                        Good Luck
                        Ron
                        • David S.
                          • August 9, 2009
                          • 595
                          Re: Tires
                          I've had BFG Radial T/A's on multiple Camaro's and a Nova. They are great tires.
                          Dave
                          • W K.
                            • December 16, 2009
                            • 61
                            Re: Tires
                            I Thank everyone for there comments and reply's. I'm going to see if I can still get the goodyear Ingegrity.
                            • John D.
                              • June 30, 1991
                              • 875
                              Re: Tires
                              Will a 205-70-15 tire have any rub issues on a stock 67 ?
