Top Ignition Shield Front Clip Rivets Small Block - NCRS Discussion Boards
  • William C.
    • July 15, 2009
    • 239
    Advise on installing rivets. Is there a tool or how do you crimp them?
  • Don H.
    Moderator
    • June 16, 2009
    • 2285
    Re: Top Ignition Shield Front Clip Rivets Small Block
    Bill
    there are past threads covering the subject
    here is a good one --->
    https://www.forums.ncrs.org/showthre...ivits&uid=4656
    • William C.
      • July 15, 2009
      • 239
      Originally posted by Don Hooper (50543)
      Bill
      Thanks Don that helps.I should have searched past threads.
      • Don H.
        Moderator
        • June 16, 2009
        • 2285
        no problemo amigo
        happy to assist
        • Gerard F.
          • June 30, 2004
          • 3806
          William,
          I remember I had a hard time trying to find just the right rivets. Just measure the head and you'll see that the usual vendor rivets don't measure up.
          But I finally settled for one of the usual vendors rivets because of the correct finish. They are hollow rivets. And you can find the backing washers for the rivets at most big box hardware stores, look in the rivet section. Got mine at Orchard Supply here in CA.
          If you follow that archived post, the modified hole punch with a 3" throat works pretty good.
          Jerry Fuccillo
