C1 body dolly - another alternative - NCRS Discussion Boards
  • Karl L.
    • February 1, 1977
    • 174
    Re: C1 body dolly - another alternative
    Originally posted by Troy Pyles (14528)
    In case we're having a contest to see who can build the cheapest body dolly I want to get my submission in.
    As seen in the attached photos my dolly consists of 4 Harbor Freight furniture dollies (2 small and 2 regular size), 6 plastic file folder containers from Target, 12 half inch screws and some carpet scraps. Total cost was about $78.
    Troy,
    Cheap is Cheap---"BUT", Functional is the "Purpose".
    Looking at your Dolly. I assume that it will never be moved very far.
    Garage to Driveway and back to Garage.
    Mark made his Dolly for: Body Support, Transporting to places to have
    it worked on, and his Body isn't going to shift if hitting a obstacle while
    moving it.
    I used a partial Dolly (given to me) for my "55". We transferred the Body
    to it and then I added Front, Back and Cross Supports to it. I was supprised how much my Body Sagged in the little time it took to install
    all the Supports. Body's have to be Supported Correctly to Prevent
    Sagging. Makes life easier after getting it back on the Frame.
    (Body Work Wise"!
    Your's might be great for not moving far, but, it doesn't look Supportive enough to keep out Body Sag.
    Good Luck to You and Mark.
    Karl.
    I like Mark's for the overall use of it.
    • Karl L.
      • February 1, 1977
      • 174
      Originally posted by Mark Pellowski (49021)
      Here is an alternative C1 body dolly I built that others may want to consider for their body-off. It worked really well this past weekend when I pulled the body on my 1960.
      I decided to do my own version because I wanted a dolly that was easy to build (2-3 hours), quite strong, would allow safe transport to the body shop and I could disassemble it easily (about 20 minutes) and store it under my house when I am not using it.
      This dolly cost me about $125, excluding the casters. I was accidently sent 2 sets of casters when I got my 4-post lift so I used one of them for my dolly. These casters are total overkill but work well. It is real easy to push the body around.
      The nose and tail supports are fully adjustable.
      Mark,
      Thumbs Up! Really looks Great!
      Karl.
      • Mark P.
        • May 13, 2008
        • 941
        #18
        Thanks Karl. So far it is working well. I get so much from the TDB and seldom get to give much back.
        • Karl L.
          • February 1, 1977
          • 174
          #19
          Subject: Re: Reply to thread 'C1 body dolly - another alternative'
          Mark,
          All the best to you. Have a "Great New Year!"
          Karl.
