Engine build date question - NCRS Discussion Boards
  • George L.
    • July 26, 2009
    • 7
    How can I find out what the build date is of a motor. I have a 1967 427, 435 hp. The vin is 194677s104820, engine code is T 11 15 JE. What I think it is the assy date for the motor would be is Nov 15 1966. Does this sound right to everybody????
    Thanks for you help.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Engine build date question
    Yes. I'd say you are correct ! Hopefully the casting date falls in line with assembly date as well.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • George L.
      • July 26, 2009
      • 7
      Thanks, Tom, where would I find the casting date?
      Thanks, George
        Thanks, George
        George -
        The casting number is on the driver's side rear flange of the block, and the casting date is on the passenger side of the block, above the pan rail, just forward of the starter, and it's upside-down.
        • Tom H.
          • December 1, 1993
          • 3440
          Hi George. I remember seeing your car when it was for sale at one time. Some of the ads stated the casting number was 3904351.
          Tom Hendricks
          • Bob H.
            • July 31, 2000
            • 825
            427 435HP #104746 is dated 11-16 on the pad. Cast date is J 14 6 which equals Oct 14th, 66. Hope that helps
