Am I missing these parts? - NCRS Discussion Boards
  • Alexander C.
    • June 20, 2010
    • 353
    Browsing vendor mags I came across a couple parts I think I am missing but I want to be 100% sure they are correct and should be on my car before ordering:
    Corvette Generator Heat Shield
    Corvette Exhaust Manifold Lock Set
    Should my car have these items being a very late 1956 build?
    Thanks! Alex
  • Mike M.
    • May 31, 1974
    • 8409
    Re: Am I missing these parts?
    yes to both questions. . the french locks were originaly mild steel, not stainless as some repos are. judges catch the stainless critters. mike
    • Dan D.
      • November 5, 2008
      • 1323
      Alex, according to the 56-57 judging guide, 56 and 57 heat shields are different. Make sure you order the correct one. They are readily available from most all supply houses. They are just a piece of sheet metal, so I wouldn't think they could screw them up too much. -Dan-
      • Alexander C.
        • June 20, 2010
        • 353
        You wouldn't think but the first vendor I checked listed the same for both '56 and '57 so strike one lol.
        Thanks!
        • Steve H.
          • November 1, 1996
          • 118
          Alexander,
          You probably won't be able to find the 56 shield. It differs from the 57 by only utilizing one bolt of the generator brace attaching bolts. You can do like I did and order 57 shield and cut it off where it only attaches by the rear generator brace bolt
          Steve
          • Mike M.
            • May 31, 1974
            • 8409
            Originally posted by Steve Huskins (28428)
            Alexander,
            Steve
            steve: you mean brace or bracket. brace goes from h20 pump to top of generator as best i can recall. regards,mike
            • Steve H.
              • November 1, 1996
              • 118
              yea bracket
              • Jerry B.
                • August 31, 1994
                • 416
                Would Someone Post A Picture Of A 56 And A 57. Thanks
                  Jerry -
                  Drawings of both shields are on page 146 in Noland's book.
