C1 windshield again - NCRS Discussion Boards
C1 windshield again
  • Richard P.
    • May 31, 2002
    • 190
    C1 windshield again
    I'm getting ready to take the windshield off for the fourth time. I had the machine fix for the broken tabs and put it back together but the windshield keeps pulling out of the windshield weatherstrip at the bottom. Anybody else ever had this problem? Is there anything that can be done to tighten the "grip" that the U channel has on the glass? Thanks.
  • Mike M.
    • May 31, 1974
    • 8409
    Re: C1 windshield again
    i've used a urethan sealer/adhesive on the last three c-1 windshields i've restored. god forbid i have to replace the weatherstrip as i'll have to cut them out. all three urethaned glasses refuse to pull away from the weatherstrip and prior to these 3 c-1's, when installing new convert top , and trying to get rid of wrinkles, i nearly always had the weather strip and upper frame assembly pull back off the glass when tightening the convert top latches. not a problem anymore with the urethane. it comes from 3-M in a caulk gun type tube.. good luck, mike
    • Richard P.
      • May 31, 2002
      • 190
      Thanks Mike. Do you seal the weatherstrip to the u-channel too, or just to the glass?
      • Mike M.
        • May 31, 1974
        • 8409
        urethane between w/s and glass and between w/s and posts/upper and lower frames. mike
