69 TAIL LAMP BACKUP LENS with 68 DATE - NCRS Discussion Boards
  • Jean B.
    • February 25, 2008
    • 49
    Hi Guys
    does anyone knows if for a early 69 vette (built date dec 20th 68)
    both backup tail lamp lenses should be dated "GUIDE 19 SAE RB 69" or
    "GUIDE 19 SAE RB 68" ???
    JF
    • 15646
    Re: 69 TAIL LAMP BACKUP LENS with 68 DATE
    That date is NOT the date the lens was manufactured. It is the date the lens meet DOT specifications. John Hinckley has posted about that in the past. Your 1968 date is fine for your car.
      • 43292
      Originally posted by Jean-Francois Bernier (48581)
      Hi Guys
      JF
      JF-------
      The outer lenses are the same for both 1968 and 1969. So, regardless of when the 1969 was built, it will have a "68" date on the outer lenses.
      The inner lens (back-up lamp) was not used for 1968. So, all 1969's will have a "69" date on the inner lenses.
        • 43292
        Terry------
        I think the practice of "dating" tail lamp lenses goes back further than the DOT even existed. Typically, the 2 digit year "date" on the lens applied to the FIRST model year the lens was used for. Thereafter, if the EXACT SAME lens was used for subsequent model years, the "date" remained the same. So, for example, the outer lenses for both 1968 and 1969 Corvettes were the same, so all have a "68" "date".
        This also applies to SERVICE lenses. The "date" remains the year the lens was first used.
          • 43292
          Hi Guys
          JF
          JF-------
          By the way, if you find any inner (back-up) lenses for a 1969 that have a "68" year code on them, I'd love to see them. I'd say those would be EXTREMELY rare. In fact, so rare that I don't think they ever existed, at all.
            Joe -
            Prior to DOT regulations/requirements, the photometrics of taillight lenses were certified to the SAE standards in effect at the time; that's what the date represents that's molded into the lens. In most cases, it's also the year the lens was first used.
