If ya'll don't mind I figured I'd post a few pictures of the restoration process of a set of 68-76 door a-jar and courtesy light switches.
First the long switches are the courtesy light switches. And the short ones are the a-jar switches.
It is a very simple process. First you remove the plastic wire terminal plug. This is done by grabbing the plug and pulling it off, this will require a deacent amount of force as the plunger is barbed at the end.
The light switches have 4 parts that disassemble. 1 the plug 2 the pin/plunger 3 the spring and 4 the housing.
The a-jar switches have 5 parts that disassemble they are the same as the light switch with the exception of the spring retaining tube.
Once they are disassembled you can then clean and replate them (cad/zinc).
Thanks.
