67 SB Ignition Shielding Pic - NCRS Discussion Boards
+ More Options
Posts
  • Kirk M.
    • June 30, 2006
    • 1036
    Can anyone show me a pic of both the front and back of an original top ignition shielding to a 67 327/300 SB. Thanks.
    Kirk
  • Kirk M.
    • June 30, 2006
    • 1036
    Re: 67 SB Ignition Shielding Pic
    Anybody? I was told I was missing a piece off the back (firewall) side of the shielding and would like to see it. Thanks.
    Kirk
      Kirk
      Kirk -
      The only piece on the firewall side of the upper ignition shield is the ground clip, P/N 3904870 (section U69, sheet A8, item #9 in the Assembly Manual); it snaps into the slot labeled "FI CARB", and grounds the shield to the ferrule on the tach cable. Photo below.
      • Kirk M.
        • June 30, 2006
        • 1036
        Thanks John. Can just that piece be purchased from any of the typical corvette dealers?
        Kirk
        • Kirk M.
          • June 30, 2006
          • 1036
          Found it at CC. Thanks.
          Kirk
