Door Panel Repair on a 1967 - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    I have the original door panels, but the are in need of repair or replacement. Eastwood sells a repair kit, but I'm not sure it'll work on my repair.
    The small corners of the armrest are shot, but the rest of the panel is okay. Any suggestions on how to "build up" these corners so the look original?
    Jerry
  • Chris E.
    • November 3, 2006
    • 1336
    Re: Door Panel Repair on a 1967
    Jerry, there is another thread on "vinyl repair" on the tech board here.
    I'd search for a local vinyl repair place in your neck of the woods. I had really good luck with a local place here in the Twin Cities.
    Chris Enstrom
    2011 Z06, red/red
    • Peter L.
      • May 31, 1983
      • 1930
      Jerry - I agree with Chris. If you don't want to tackle the job (even if you do), check around locally. Doing it is a PITA and they might do the job for a lot less and much better. Pete
