Photo needed THM400 and 3x2 - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    I need the vacuum line from the trans to the intake manifold. I bought one from Paragon which is a "replacement" for 69 but it seems to be designed for a single carb manifold. Does anyone have a picture of the area around the distributor and rear carb with an automatic? Or any photos showing this line up by the engine? Any leads on where I could get the correct line? It never ends....
    Mike
  • Steven C.
    • April 30, 2002
    • 199
    Re: Photo needed THM400 and 3x2
    Have you checked the AIM?
    • Mike R.
      • August 30, 2009
      • 321
      The AIM does not give any guidance. It is probably supposed to be the same tube as other applications just bent. I need a photo to see "how" it was bent.
        • 15640
        Does this work for you?
          • 15640
          I would guess the vacuum tube for the M40 with 3 Holleys came to St Louis pre-bent. The installers had to chose the proper tube for the application. At least that would be my guess. Bending the tube very much on the line would slow installation and could lead to noise in operation.
          • Mike R.
            • August 30, 2009
            • 321
            It might. I will install the ignition shielding doghouse and see if the line I have goes around it as in the photo. Thanks!
              • 15640
              If you want a version that will blow up bigger, send me a PM with your email address and I will send you the original. We can't send attachments through this board.
              • Mike R.
                • August 30, 2009
                • 321
                This might be good enought. I need to see if the line I have goes around the ignition shielding as does the line in your photo. The end of the line is *right* at the fitting on the intake manifold but not lined up with any of the ports.
                • Ridge K.
                  • May 31, 2006
                  • 1018
                  Mike, I just sent you an email.
                  Ridge
                  • Mike R.
                    • August 30, 2009
                    • 321
                    I wasn't able to get the ignition shielding on today to see how the line is routed relative to it but I did take this photo. The line I have looks different that the one in Terry's photo.
                      • 15640
                      • Mike R.
                        • August 30, 2009
                        • 321
                        That is what it looks like to me too. I hate to twist hard lines they should really only be bent. I have no problem getting the line to mate, my concern is to do it in a way that was typical of production.
                          • 15640
                          I understand, but the twist will be in a fairly long run and shouldn't present too much of a problem.
