Wiper door vacuum safety switch AC or repro? - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    How can I tell if a vacuum safety switch is an authentic AC part or a repro? Thanks.
  • Jerry B.
    • August 31, 1994
    • 416
    Re: Wiper door vacuum safety switch AC or repro?
    The Original Ac Switch On My 1969 Has A Black Topnot White. Maybe Joe Can Chime In.
      • 6960
      Mike, Jerry is correct on the black top hat. take alittle black sharpe and color it black. or if you have some stove black that will work.
      • Mike R.
        • August 30, 2009
        • 321
        I bought this on ebay. It was supposed to come in the pictured AC box. It arrived without the box and has no manufacture's logo. On it. The top is actually a gray color.
        Mike
          • 6960
          Mike, I am not even sure that the factory switch had any markings, or part no.s
          I think that when you buy things on ebay they trick you into thinking your buying a replacement part , they just send you one from a reproducer. and keep the box.
            • 3422
            Hi Mike,
            I took a look at the original safety switch from my 71 in comparison to a reproduction switch.
            The most obvious difference in configuration I can see is that the original switch has a perfectly round barrel that the nipples originate from. The reproduction switch's barrel has a distinct flare running along it's entire length.
            Another slight difference is that the nipples on the original have moulded openings at their ends while the reproduction has a very sharp 'cut off' look the them.
            I'll be interested in hearing what your part looks like.
            The original is the switch with the plunger cap broken off.
