C4 Headlight gear replacement - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    I replaced the very brittle and broken gears in the headlight motor for my 88 with new OEM gears. The installation was straight forward but when turing the lights on the passenger side does not open. The motor and worm gear are turning fine though, gear is installed in its proper location. Do the internal gears need to be oriented a specific way relative to the worm gear? Not sure what I missed?
    Any help is greatly appreciated,
    Pat
    68 427 / 400
    88
  • David H.
    • June 30, 2001
    • 1564
    Re: C4 Headlight gear replacement
    Were the bushings bad?
    • Patrick N.
      • March 10, 2008
      • 954
      yup, replaced the bushings during the job, they were shot.
      Thanks for the link- they mention setting the linkage back to "closed" prior to installing. Motor and worm gear work and engage the gear, nothing catches but it does not cycle correctly. I think may be the issue, I will give this a try and hope that is all it is.
      Thanks again!
      Pat 69 427 / 400
      88
