disassembling convertible top frame - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    I have disassembled the convertible top frame for sandblasting and painting. There is one bow that is not screwed to the end (hinge) sections. It appears to be only slid into place, I can't see any welds but it does not want to come out. Is this piece in fact welded or is mine just corroded into place and I just need a larger hammer? Thanks
  • Terry B.
    • August 31, 1999
    • 607
    Re: disassembling convertible top frame
    Mike,
    I was considering having my convertible top frame sand blasted and then repainted but a restorer told me if your top is folding and working correctly, do not have it sand blasted as it will cause problems with the folding area hinges and pins. He said to sand the frame with a hand sander and your frame will come out without folding problems. However, if your frame already has problems with the folding mechanisms, then it's a mute point.
    Any pictures you can send of the project?
    thanks,
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Mike R.
      • August 30, 2009
      • 321
      Thanks Terry.
      There is some rust on the folding portion which will require blasting to remove. We will just have to be careful. I prefer not to blast anything I cannot get completely apart but in this case I have to.
      I will be posting some pics soon. I have been delayed from completing certain tasks while I wait for parts. The chasis is awaiting some upper control arm rivets. I had them all riveted and then decided I didn't like the finish and started over. Then the second set of rivets came and did not look like the first so now I have been waiting two weeks for six rivets.
      I am really hoping to be completely done with dirty work (except for the body) in the next week or two.
      Originally posted by Terry Buchanan (32872)
      Mike,
      thanks,
      • G A.
        • February 18, 2010
        • 229
        Hi Mike,
        I am starting my soft top restoration after the first of the new year. I would be interested in photos and your experiences also.
        Have been putting it off because I detest anything that smells of sandpaper and paint, but the time has come. I would avoid sandblasting for the reasons previously stated. Since the spot of corrosion is small, have you considered a mild grinding with something like a Dremel?
        -Dan
        • Tracy C.
          • July 31, 2003
          • 2739
          Originally posted by G Dan Andrews (51435)
          Hi Mike,
          -Dan
          Agree..wire wheel on a drill motot or chemical rust remover will keep you grit free.
          tc
          • Rich P.
            • January 12, 2009
            • 1361
            These can be glass beaded and cleaned with no problem. I have done many.
            What I do once the frame has been blasted is to blow out all the joints then I use thinner from a sure shot can and work each joint useing the thinner to wash out the media as I work the joint back and forth. You can feel the grit disappear. Once the frame is in final paint I use oil on each joint and the tops work perfectly. I do the same thing with 68-72 wiper door hinge assemblies.
            For those wondering what a sure shot can is it is a refillable bottle that you can pressurise with air and use like a spray can. In a pinch you can just put thinner in a spray/paint gun and use it the same way.
            Rich
              • 6941
              Rich, I have a question on folding top on my 63 that I just purchased I noted that the area over the window is not straight, it does not follow the contour of the upper windows, is this due to the it being a older top and has srunk over the years causing the top mechanism to have this problem? or maybe something that will need to be addressed when I remove and install a new top ? thanks Ed
              • Rich P.
                • January 12, 2009
                • 1361
                Ed,
                if your talking the bound edge above the side windows not being straight then it is most likely from not being properly installed or like you said shrinkage/ stored in the down position too long. Let th top rest in the up position and the next sunny day let it sit in the sun to see if the top streaches and lines up. Or you could use a heat gun and warm the area up.
                Rich
                  • 6941
                  Rich, Is there some sort of a adjustment on the bound edge? The top was dated 1979 and the car was sitting many years, in what position? Who knows., my reason for asking I am planing to replace the top during my resto. and if theres anything to look at while apart , I want to correct.
                  • Rich P.
                    • January 12, 2009
                    • 1361
                    Ed,
                    the "bound edge" is aligned while the top is being installed. It is attached on the header by tacks/staples, over the side window under the top horizontal weatherstriping and on the bow where the windlace is attached (just above the rear window). Many times the pads are installed incorrectly making the top incorrect. I would check to see if the pads line up straight or look just like the canvas.
                    In other words it usually is not the frame but the top and pads causing the problem. Whoever installs the top for you will be able to determine if the frame is ok.
                    Rich
