After doing a series of tests to the alt/reg/battery circuit and after replacing a spent alt, bad regulator and a cooked battery, I'm still no further ahead!
I installed a new Die Hard Gold battery today with 12.96 VDC. Hooked up my voltmeters to the alt wiring and one to the battery terminals to watch voltage. I started the car and the charging began at 13.2 but the higher the RPM, the higher the voltage, all the way to 19+. I shut the engine down and started running all the tests all over again. I ran continuity on all wires to and from the alt back to regulator. The "F" terminal (dark blue wire) was good, the "R" terminal (black/white wire) good, red terminal was good also. I found that my #4 wire in the voltage reg plug (black/pink wire) has continuity with any ground I touch. I disconnected the firewall connector and had continuity from regulator to firewall connector pin. However, no ground condition in the engine compartment. Does anyone know where the BLACK/PINK wire goes once it crosses under the dash? Apparently, something inside the car is causing a ground condition which somehow keeps my alt in the high charge mode.
