Sorry to revisit this, but I am getting ready to order the rebuild kit for my T10. It is a 1960 which means close ratio. The car had a 3.70 non-posi, but originally was posi based on the axle housing and vent line.
Here is the story so far, I am in the process of rebuilding the rear with a correct P case carrier that I was able to locate and Eaton posi unit per Tom Parson's article. I have decided to go with 3.36 gears. Simple reason is that I want to be able to cruise at 60-65 mph without taching at 3,000 or near for extended cruising.
Since this is my first restoration and I don't know what I don't know, I think I have researched all the issues, i.e. buring out clutches, etc. When I took it apart it had an 11" clutch, so I assume that will help with the close ratio first gear and clutch burn out issues.
So my question is, should I convert the T10 to wide ratio? I know with wide ratio and the 3.36, the overall ratio in first is about the same as a close ratio and 3.70 rear. But if there is experience that says the 11" clutch will solve the issue of having 3.36 rear, then I will save my money.
I also know, or think I know, that converting to wide ratio will not affect flight judging, which I am pursue, but will likely fail if I were to pursue Duntov, which I am not considering.
Thanks in advance
Don
Thanks in advance
Don
