Newbie Questions - NCRS Discussion Boards
Newbie Questions
  • Marlin F.
    • November 29, 2010
    • 27
    Re: Newbie Questions
    On your throttle sticking, be sure to check the breather tube that connects under the air cleaer base and goes to the back of the block. If that tube is off, it will bind the throttle lever, it has happened to me when the air cleaner has been removed and not properly reinstalled. Good luck and welcome.
    Michael, you nailed it on the head! Apparently someone at the auction had removed the air cleaner assembly and not replaced it properly. I put it back together and everything works fine now. I'm sure glad it wasn't a motor mount!
    Again, thanks to all for your helpful comments!
    Marlin Fiola
    • Michael J.
      • January 27, 2009
      • 7158
      Marlin Fiola
      Great, glad I could help. Since I am not a professional mechanic I always try to start with the simplist, cheapest, and most logical things first. Motor mounts are way down the list.
