1960 Top Tank Radiator Label Placement - NCRS Discussion Boards
  • Wayne P.
    • October 28, 2007
    • 1
    Can anyone help me with the correct label placements on an aluminum top tank radiator. 283/270hp (if any) Thanks
  • William G.
    • May 31, 1988
    • 16
    Re: 1960 Top Tank Radiator Label Placement
    just slightly left of center, left being the drivers side
    • Loren L.
      • April 30, 1976
      • 4104
      If your top tank has the five ribs (most do), the position is dicated by the shortened 3rd rib; the aluminum label goes into that unribbed area located +/= 7/16" from the 2nd and 4th ribs, with the stamped date on the label closest to the windshield. The original I have on hand is a 60A.
      Pictures I have of the unribbed tank show the emblem in relatively the same location.
      • Jim D.
        • 2885
        Loren, I believe the OP is referring to the anti-freeze warning sticker.
        • Loren L.
          • April 30, 1976
          • 4104
          So do I. And according to the blueprint for #3147516, the language on the aluminum plate is: "Use only anti-freezes and other additives specifically recommended by their manufacturers for use with aluminum.
          See owner's manual for service information.".
          On the blueprint for #3151116, the same language is repeated.
          It is interesting to note that on both blueprints, the dating scheme is called out as "B-60" and "B-61", contrary to the "60-A" that was utilized.
          • Jim D.
            • 2885
            Not the aluminum plate, the gum backed paper sticker.
