Scuffed rear window on C2 soft top - NCRS Discussion Boards
  • Elio D.
    • November 23, 2010
    • 37
    hi , I would like to know if there is any way of removing scuff marks on the rear plastic window or can just the window be relaced. thanks
  • Bob H.
    • July 31, 2000
    • 829
    Re: Scuffed rear window on C2 soft top
    Elio:
    I have cleaned up and removed minor scratches using a plexiglass polishing compound on a couple of cars. It worked very well. I used what was originally made for aircraft windows but I know there are several other products out there. It just takes some patience when working on it.
    I wonder if some of these headlight polishing kits might work? I always did mine by hand, not machine.
    Bob
    • Bruce B.
      • May 31, 1996
      • 2930
      Elio,
      Meguiars sells 3 products which work very well on convertible top plastic windows and Plexiglass used on hardtops. I have used it on both.
      They are #17 a cleaner, #10 a polish and #18 a detailer. Use all 3 and the results are great.
      They are sold under Meguires professional products online or in stores.
      • Daniel K.
        • April 1, 2002
        • 190
        Eilo,
        Used the above mentioned products with a random orbital polisher on a 63, 356 I'm restoring. I knew I was going to replace the soft top so I went after that rear window which was difficult to see through with gusto since I had nothing to lose. Turned out excellent and the top was early '70's vintage. Also, I used the soft pads on the polisher.
        • Paul L.
          • November 1, 2002
          • 1414
          I use this product on my 1974.
          • Steven B.
            • June 30, 1982
            • 4018
            Elio, I use the Meguiar's products also with very good results. In the 60's before many of these products existed I used Allison's Aircraft Plexiglass Cleaner and for severe scuffs I used watered down toothpaste. The toothpase also worked on Polo White nitrocellulose lacquer to remove the yellowing oils as did white polishing compound. My paint never had a cavity.
            Steve
            • Stuart F.
              • August 31, 1996
              • 4676
              Speaking of cavities; I always wanted to polish my hardtop window, but it has stress marks in it from being stowed on end. Also, when you do any kind of polishing, don't you get a distortion? I guess this would only be important on a glass windshield.
              Stu Fox
              • Elio D.
                • November 23, 2010
                • 37
                Thanks to everyone who replied so quickly,l have some of the headlight polish l used on my domestic cars with great sucsess so i,ll try it on a small area.This was my first season with my 64 and my wife and l enjoyed putting on 3500 miles crusing.Its going to be a busy winter, the car is going in the shop in Febuary for a new front clip,bumper ,grill ,grill trim,front harness,new mounting hardware,paint,polish,repair to some gauges and or dash harness.Carb is getting rebuilt,glovebox restored and l have to rebuild the waterpump again (bad bearing).So i,ll be also joining the Ontario chapter.Going to be a long winter but she,s going to be a sweet spring. Thanks again from a new member and Merry Christmas to all. Elio
