C2 Rear Deck Lid issue - NCRS Discussion Boards
  • Jerry L.
    • November 3, 2008
    • 36
    My 66 Roadster rear deck lid sits high in relationship to the rear clip. It does not appear to be a weather-strip issue as there is little apparent compression of the rubber. I cannot detect any bending on the hinges although that appears to be the only way to draw the lid down for a proper fit. There are no shims at the floor mount of the spring assembly that I can detect. Am I missing something or is there an easy fix for this issue?
    Thanks in advance,
    Jerry
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 Rear Deck Lid issue
    Put shims under the front bolts of the lid mount. It will lower the lid at the rear.
    • Jerry L.
      • November 3, 2008
      • 36
      Wayne,
      Well that sure is simple! What would be an acceptable shim and where can they be purchased?
      Jerry
      • Wayne W.
        • April 30, 1982
        • 3605
        You will see factory shims occasionally. What I have seen is a U shaped body shim. There could be other styles.
        • Michael G.
          • January 1, 1997
          • 1251
          Jerry,
          U shape shim is typical....won't take much thickness w/shim at front bolt to make a difference where lid meets deck.
          • Jerry L.
            • November 3, 2008
            • 36
            What are the rough dimentions of the shims? I may have some around here of various sizes from other GM rebuilds..
            Thanks again,
            Jerry
            • Timothy B.
              • April 30, 1983
              • 5194
              Wayne,
              My 67 deck lid sits up slightly in the rear and I always thought it was the later GM weatherstrip installed in the 80's.
              Can you comment on the GM rubber, I am not sure if I should try to shim or remove the weatherstrip first to see if it sits flat.
              • Michael G.
                • January 1, 1997
                • 1251
                Wayne,
                Would think fitting the shim would be the 1st choice.....then possibly the w/s dependent on results.
                  Jerry -
                  Corvette Central sells a set of curved/slotted half-shims for that deck lid shim application - their #541175.
                  • Jerry L.
                    • November 3, 2008
                    • 36
                    Thanks John,
                    I see the description is for the C1's, were they also used in the C2
                    Jerry
                      Originally posted by Jerry Larsen (49643)
                      Thanks John,
                      Jerry
                      Jerry -
                      They work fine for either application - same bolt size.
                      • Scott K.
                        • February 1, 1980
                        • 59
                        Jerry -
                        Actually, use our shims listed as part # 242033 for 1963-67.
                        Link: http://bit.ly/guXDRs
                        Corvette Central
                        800-345-4122
                        www.corvettecentral.com
