1962 - Really an original 340hp car? - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    Hello,
    I am going to look at a project car (in pieces) that the owner claims is an original Feb 62 built, 340 hp, 4 speed.
    I know to look at the Higher Red Line tach, as well as all of the engine related stuff (stampings on block, heads, manifolds, intake, carb, generator), but what else should I look for to do "my best to verify" it was originally a 340hp?
    Tony
  • William C.
    • May 31, 1975
    • 6037
    Re: 1962 - Really an original 340hp car?
    Correct valve covers with no casting flaws, and look for an ORIGINAL high performance '62 Corvette oil pan. If you don't have a good description, do a search in the archives and there is much info on the unique configuration of the SHP pan which was a '62-340/360 horse only item. If you are running short on time, drop me a PM and I'll slide under my '62 and grab you some pictures.
    Bill Clupper #618
    • Anthony P.
      • June 27, 2010
      • 485
      Thanks Bill. In addition to all of the engine related items and tach redline, are there any other differences, such as in the suspension, or other components?
      Tony
      • William C.
        • May 31, 1975
        • 6037
        Unless equipped with the "off road" suspension option (race package) nothing was changed in the body or frame for a base vs 340hp car. Same suspension unless specifically selected as options, and those would have been available on any engine package
        Bill Clupper #618
        • Anthony P.
          • June 27, 2010
          • 485
          ok, thanks Bill. this was very helpful.
          Tony
          • Mike E.
            • February 28, 1975
            • 5141
            Finned balancer. Timing chain marker with a point, not a rectangle, welded to the cover, not bolted. Properly dated 985 distrib. Generator mount plate is different than 250 and 300 hp plate. Those are some subtle things that come to mind immediately.
            Good luck!
            Mike
            • Jerry W.
              • January 27, 2009
              • 588
              look for 4 inch dia generator pulley vs 3-5/8 dia. for base engine generator.....the crank damper/balancer was much larger in diameter than base engine....8 inch dia. i think....causing the timing tab on the cover to be welded futher out from the crank to accomidate the larger balancer dia.....also high rise aluminum intake with oil fill on passenger side of car...the throttle return spring anchor bracket is mounted with a single intake manifold bolt just forward of the left valve cover....engine would have solid lifters....dual points distributor with mechanical advance ( no vacumn can )
              • Anthony P.
                • June 27, 2010
                • 485
                Thank you for all of the pointers.
                Tony
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Also, 1110985 non vacuum advance distributor.
