700 miles on a new motor and it came untied. I bought a 72 lt1 form a corvette dealer in 2007. it will be a recreation of my high school car. it had just had a fresh rattle can restoration, cheap paint job and a freshly rebuilt motor. i bought this car to build as a driver. i got all the recipts for what was done to the motor so i was satisfied with what i got. i drove it for a week and pulled it into the garage and pulled it apart. i sent the body to the body shop and i went to work on the chassis. nearly 3 years later i got the car put back together. the more i drove the car the worse it ran. i drove the car down the interstate and it started to make alot of noise so i turned around and went home. by the time i got home it had lots of valve noise and what sounded like a rod knock. it would backfire through the carb and i could barely keep the car running. i pulled a valve cover and 2 valves were not moving.
it looks like whoever built the motor did not zinc coat the cam shaft before they installed it. we pulled the motor and tore it down. 3 lobes on the cam were gone. all of the metal from the cam went down to the pan and worked its way through the bearings and crank. i had to replace the crank, all the bearings, cam shaft, lifters,oil pump and rings. so much for buying a car with a fresh motor.
the motor is rebuilt and back in the car. i am now in tuning hell. i can get the car to idel good or run good. i cant seem to get it to do both. the holley carb on the car is not correct. it is a 750 dp. might have to replace that too. this car has turned in to a money pit.
it will be a fun car if i can get it to act right.
