Re: 57 Corvette Power Window Option - NCRS Discussion Boards
+ More Options
Posts
  • Jerry B.
    • August 31, 1994
    • 416
    Would Someone Post The Proper Position For The Window Switches On The Drivers Side Door Panel. That Is, The Forward Switch Should Control The Left Or Right Hand Window? Thanks
  • Bruce B.
    • May 31, 1996
    • 2930
    Jerry,
    I can't positively answer your question but based on the power window setup which is sitting on the bench everything is predetermined by the harness. But I do believe that the front switch operates the passenger side window.
    • Mike T.
      • January 1, 1992
      • 568
      Jerry, I've found the same as Bruce described...that the nearest button to the driver (meaning the rearmost button) is typically the one that controls the drivers window. At least in all the older GM cars, that's what I've found.
      Mike T.
      Mike T. - Prescott AZ.
