Re: Engine Coolant Change
On my 63 I used Prestone Dexcool after installing the new DeWitts radiator. After seven years I changed to G-05 and distilled water but the dexcool looked like the day I put it in the engine.
IMO, the only way to properly change the coolant on our old cars is to remove the block drain plugs. I usually drain everything then remove the 5/8" heater hose from the manifold and blow through to get the coolant out of the core. After that I put a few gallons of water in the expansion tank then open the block plugs to drain. You will be surprised how much rust and sediment will be removed and it only takes a few minutes of extra time.
Biggest PIA is removing the wire shields to access the block drain plugs but you feel the system is cleaned out good when finished.
