ammeter operation (fluttering) - NCRS Discussion Boards
+ More Options
Posts
  • James S.
    Infrequent User
    • March 1, 1984
    • 19
    After installing a new battery and a couple of weeks of tuning a Re-ferbished Power Top system I suddenly developed a Amp meter fluxuation (May have been created by use of excessive 40 Amp charging ?). Not claiming to be a Electrican has anyone dealt with this issue (step by step) , and what the correct way to polarize a C1 Voltage reg ????? Thanks in advance Jim S.
    Re: ammeter operation (fluttering)
    Jim -
    Use a U-shaped piece of insulated wire, stripped at the ends, and touch it briefly to both the "Bat" and "Gen" terminals on the voltage regulator, with the engine not running; you'll get a spark. Done.
    • James S.
      Infrequent User
      • March 1, 1984
      • 19
      Jim -
      Hey John !!!! Thanks for info, didn't fix fluctuation but points me in another direction. I'll probably pick your brain on Sat. Jim
