1962 seat tracks - NCRS Discussion Boards
1962 seat tracks
  • Kenneth F.
    • September 30, 1988
    • 285
    1962 seat tracks
    Do the front of the seat tracks on a '62, bolt directly to the floor, under the carpet? If so, how far into the carpet should I cut, if I need to create flaps to cover the tracks?
    Ken
  • John F.
    • March 23, 2008
    • 2424
    Re: 1962 seat tracks
    Yes they bolt to the floor. One bolt on each side rail in the front. Trim as needed.
    • Bruce B.
      • May 31, 1996
      • 2930
      Yes they go into a nut plate which is rivited to the underside of the floor.
      I believe the outside screw (near the door) goes through the carpet ( bracket on top of carpet) and the inside screw is covered by the carpet .
      But I might be wrong, hopefully someone else will comment.
      • John T.
        NCRS Financial Officer
        • January 1, 1983
        • 293
        Per the judging guide and my experience, the seat rails should bolt directly to the floor. They should not be on top of the carpet.
        Hope this helps
        John
        • Kenneth F.
          • 285
          I appreciate all your responses. I bolted the tracks directly to the floor, and the carpets could be lifted enough without cutting, to install the bolts.
          Thanks, Ken
