64 Oil gauge tube - NCRS Discussion Boards
64 Oil gauge tube
  • Vincent B.
    Infrequent User
    • February 8, 2010
    • 17
    64 Oil gauge tube
    I am replacing the oil pressure line that goes from the gauge to the engine block. Does this line need to be filled with oil, bled while the engine is running or just left dry?
  • Bob H.
    • July 31, 2000
    • 810
    Re: 64 Oil gauge tube
    Hi Vincent:
    you can just install it and it will fill on its own.
    Bob
    • Stuart F.
      • August 31, 1996
      • 4676
      Besides, how did you plan on filling that little sucker??
      Stu Fox
      • Tracy C.
        • July 31, 2003
        • 2739
        Be sure to use a copper plated steel line as original. Some of the repops are just a copper line and over time it will fatigue, crack and make a mess.
        tc
