Wrong Driveshaft? - NCRS Discussion Boards
Wrong Driveshaft?
  • Mike R.
    • August 30, 2009
    • 321
    Wrong Driveshaft?
    The driveshaft that came with my 69 BB automatic trans car is 29.5" from the center of one u joint to the center of the other one. With the engine, trans and rear suspension mounted I cannot get the driveshaft in with the trans yoke all the way in (I even tried taking the ujoint caps off.
    What should the dimensions of the driveshaft be for a C3 with TH400 ?
    Thanks in advance!
    • 43281
    Re: Wrong Driveshaft?
    Thanks in advance!
    Mike-----
    The THM-400 driveshaft is supposed to be 29.5" from u-joint center-line to center-line. The manual trans driveshaft is 29.9".
    Another check you can make is driveshaft tube OD. The THM driveshaft should be 2-1/4" OD. The manual trans driveshaft is 2" OD.
    • Mike R.
      • August 30, 2009
      • 321
      Thanks Joe. I will measure the diameter and remeasure the length.
      Mike-----
      • Mike R.
        • August 30, 2009
        • 321
        I think the problem is the yoke. Please look at the photo and let me know if this is the wrong one.
          • 43281
          Mike------
          This yoke is NOT configured like the correct GM #3930827. I'm not prepared to say that this might not be some sort of aftermarket replacement for the correct yoke but given your experience with it, I would say it's likely not.
          • Mike R.
            • August 30, 2009
            • 321
            Thanks Joe, the only identification on the yoke is SPICER. From photos in catalogs I am pretty sure this is a GM yoke but the wrong one. Another mystery solved and another step closer to completion.
            Thanks again.
            Mike
            Mike------
            • Wayne W.
              • April 30, 1982
              • 3605
              The picture is a little dark, but the yoke does not appear to have the straps so you can remove the yoke. The Corvette has a removable yoke. You cant install or remove the drive shaft with that arrangement, unless you have either the rear or the engine out.
              • Mike R.
                • August 30, 2009
                • 321
                Sorry, I thought is was apparant in the photo that it is the type with straps. Anyway, is has been determined that it is not for a Corvette.
                • Gary R.
                  • April 1, 1989
                  • 1806
                  I'm rebuilding a 69 BB 4 spd shaft now, it is 29.9 center - center.
                    Mike -
                    The slip yoke should look more like the one in the photo below, which places the centerline of the U-joint trunnions closer to the end of the splined tubular section.
                    • Mike R.
                      • August 30, 2009
                      • 321
                      Thanks Everyone, fortunatly for me, Tom's Differentials is right down the street and, not only did he have the yoke, he also had the lowest price too. Driveshaft in a and bolts torqued....check
                      Mike -
