66 fuse panel or fuse block - NCRS Discussion Boards
  • Tauno M.
    • April 21, 2010
    • 15
    i've tried my chasis wiring diagram, my assembly manual, supplier catalogs with no luck. i know it can be done by trial and error but, i was hoping someone with more knowledge than me can tell me where to find this info.
    is there a "map" of what fuse goes to what devices??? thanks
  • Randy S.
    • January 1, 2003
    • 586
    Re: 66 fuse panel or fuse block
    Tauno
    The best picture I could find is in the owners guide pg 47
    Randy
    • Tauno M.
      • April 21, 2010
      • 15
      thanks, don't have one but will have to get it.
      • Randy S.
        • January 1, 2003
        • 586
        Tauno,
        I think you are asking for what each circuit feeds as the fuseblock lettering is not legible. If so here it is from top of block to bottom 6 circuits/fuses total
        1 Parking brake alarm & Gas gauge AGC 10
        2 Heater AGC 10
        3 Radio AGC 2.5
        4 Panel lamps inst radio and clock lights AGC 4
        5 Tail and Back up lights AGC 10
        6 Courtesy,Stop and License SAE 20
        Hope this helps
        Randy
        • Ronald L.
          • October 18, 2009
          • 3248
          The detail is also show in the 66 AIM, electrical section, someone may be able to scan & post that page for you, mines up north...
            Tauno -
            Photo below shows a '66 fuse block.
            • Tauno M.
              • April 21, 2010
              • 15
              the picture is great. thanks.
              • Wayne M.
                • March 1, 1980
                • 6414
                Tauno -
                And here's the backside of a '66 or '67.
                Be aware that if you have C60, if I'm not mistaken, you should have a 30 amp fuse in the heater slot, rather than 10 amp. [Ref. '65 AIM UPC C60, Sheet E2, item #6; other MY's should be located close by].
