Ls7 - NCRS Discussion Boards
Ls7
    • 43248
    #61
    Re: Ls7
    Originally posted by John Neas (171)
    What would be a value range for a NOS LS-7?
    Regards
    John------
    I don't get into "value opinions" very often. In this case, while the LS-7 might be very desirable, it's not going to be of value to anyone doing a restoration. Once out of the restoration market, I would say it's value ought to be about the same as the cost to build up an equivalent engine from easily available parts.
    Is the engine that you are referring to an original configuration LS-7 with aluminum heads or is it the 3965774 with cast iron heads?
    • John N.
      • February 1, 1975
      • 451
      #62
      Re: Ls7
      John------
      Joe
      Iron heads. Thanks!
      Regards
        • 43248
        #63
        Re: Ls7
        Joe
        Iron heads. Thanks!
        Regards
        John------
        Not that I'm suggesting this, but if you were to "part out" the engine, the new pieces should bring somewhere in the range of $3,000 to $5,000. So, the complete engine assembly ought to be worth at least that much.
        The problem is the 12:1 compression pistons. No one (in their right mind) is going to want an engine assembly with that kind of compression for the street. And, for most racing applications the engine, as-is, will not be enough for most guys these days.
        • John N.
          • February 1, 1975
          • 451
          #64
          Re: Ls7
          Joe
          Thanks!
          Regards
