Rear End Grease - NCRS Discussion Boards
Rear End Grease
  • William G.
    • April 1, 1978
    • 154
    Rear End Grease
    I have a 65 non-positrack rear end --what type of grease should I use in it? 90 weight gear lube or can I use positrack gear lube in it? If so, do I need to put an additive in it?
    Thanks, Bill
  • Mike M.
    • May 31, 1974
    • 8409
    Re: Rear End Grease
    90 wt gear oil adequate for non-posi rear. mike
      • 15706
      Re: Rear End Grease
      Any SAE 80W-90 GL-5. Brand is not important. Like engine oil, buy gear oil based on viscosity and API spec. GL-5 is the universally used API spec for hypoid gear sets.
      An open differential does not need the Positration additive.
      Many gear oil packages say the are "suitable for limited slip differentials", but that does not mean that they have the additive installed. In fact, most don't.
