Cranking Vacuum - NCRS Discussion Boards
Cranking Vacuum
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 291
    Cranking Vacuum
    What would be the expected cranking vacuum on a 1962 250 HP 327 ?
    Any thoughts are appreciated.
    John
    • 15673
    Re: Cranking Vacuum
    It would be highly dependent on cranking revs and throttle position - on the fast idle cam for a cold start? On the curb idle stop with no manual opening of the throttle?
    A hot start with the throttle at least one-quarter open will generate only very low manifold vacuum and virtually no signal at the venturi, which is why at least half throttle is proper for "unloading" a flooded engine and is often necessary on carbureted engines due to fuel percolation that creates an over-rich condition in the manifold.
    • John T.
      • January 1, 1983
      • 291
      Re: Cranking Vacuum
      Trying to diagnose a "no start" problem Cold engine, throttle closed, all vacuum ports plugged.
      Is there a ball park vacuum figure I should expect ?
      John
        Re: Cranking Vacuum
        John
        John -
        Lots of variables involved, which is probably why no such spec has ever been published.
        • Jim L.
          • September 30, 1979
          • 1808
          Re: Cranking Vacuum
          I'd expect the cranking vacuum signal to be no greater than 3" Hg, and probably less than 1" Hg.
          Jim
          • Clem Z.
            • January 1, 2006
            • 9427
            Re: Cranking Vacuum
            this is why you need the choke to close fully to cause a high vacuum in the carb venturi area so fuel will flow thru the boosters from the float bowl to start a cold engine..
            • Bob H.
              • July 31, 2000
              • 809
              Re: Cranking Vacuum
              how about details such as what you have done so we can maybe come up with some fix?
