Who on the hotline is a noted carb Guru on these carbs, would love to get these to start at three of four cranks, everything has been adjusted to specs, floats, chokes,etc, starts quick if shot with starter fluid, can I adjust the screws in or out, (which ones), on top to richen or lean the mix until I get it, or what do you do for a final and quick pop, when these old 6's dont pop quick they usually drag down the battery quick, any help would be highly appreciated. Thanks again, Brad. (I smell turkey)
