67 Gas Cap - Gasket Adhesive - NCRS Discussion Boards
  • Nicholas V.
    Infrequent User
    • March 1, 2001
    • 6
    I have just acquired a replacement gas cap for my 67 Corvette. It came with the fiber gasket separate. What kind of adhesive would be best to use on it? Thanks!
    Nick
  • Donald O.
    • May 31, 1990
    • 1593
    Re: 67 Gas Cap - Gasket Adhesive
    I don't believe that there should be any adhesive.
    DonO
    • Larry M.
      • January 1, 1992
      • 2702
      Nick
      I used 3M Super WeatherStrip Adhesive (#08001). I used the yellow original color, but it is also available in black.
      Use sparingly for best appearance.
      Larry
      • Brian M.
        • February 1, 1997
        • 1842
        I'm with Don on this one.
        DonO
        • Bill I.
          • January 29, 2008
          • 554
          It's supposed to be loose. Bill
            • 43287
            Bill------
            I agree. The cellulosic (cardboard) gasket used for 1963-68 was not attached with any adhesive. However, the neoprene gasket used for 1969-74 was affixed with a neoprene solvent cement.
            • Richard J.
              • February 18, 2010
              • 46
              Larry
              I've used it on a new style gasket. Gas will attack it in time. Went back to old gasket.
              • Joe C.
                • August 31, 1999
                • 4598
                Nobody will know that you used adhesive if you're afraid of losing it. It will eventually stick of it's own accord W/O adhesive.
                Gasoline will attack weatherstrip adhesive, which is very simply thick contact cement.
                If you want to put a few inconspicuous dabs of adhesive on there just for kicks, then use Permatex Hi-Tack, which is impervious to gasoline.
