'61 Rear Axle Housing - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    Is the rear axle housing on 1961 different for positract and non-positract? In other words can I put a posi unit in a housing that was not originally a posi housing? I am trying to do that and the vent line isn't lineing up and the pictures I find are confusing on this point.
  • John F.
    • March 23, 2008
    • 2408
    Re: '61 Rear Axle Housing
    Contact Tom Parsons on this forum. Or do a search on it. Tom wrote an excellent article on it.
    • Tom P.
      • April 1, 1980
      • 1814
      Without exception, ANY 55-64 pass car rear and ANY 56-62 Corvette rearend center section is a 100%, direct bolt-in into any of those axle housings. PERIOD.
      The NON-posi Vette housings had a vertical vent with a loosely crimped on cap. The vent was serated on the lower end and just tapped into the hole in the housing. The posi vent had a 90deg elbow that was threaded and screwed into the same hole. There was a length of 3/16in steel tubing (same size as brake line) connected to the elbow that went over to the clip on the center of the housing (same clip that was bent over the brake line).
      • Ray C.
        • June 30, 2001
        • 1132
        Hi! Tom,
        The posi housing has a splash/drip shield on the interior of the housing. Is this shield needed to help lube the posi unit?
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
        • Tom P.
          • April 1, 1980
          • 1814
          As I understand it, under extreme conditions (such as competition), it helps to direct more oil onto the ring gear teeth. This is one of the welded-in features of a posi axle housing that cannot be seen from outside. Yes, the posi housings have the long vent line which is one of the things that identifies a posi housing, BUT, that can be added to ANY housing, and once added, it will look just like a posi housing---------------------------well, sorta. A posi housing will also have a circular posi tag around the filler plug, which is now reproduced.
          The round one was used up through 62, the one with the flat side is 63-64.
          • Gary C.
            Administrator
            • October 1, 1982
            • 17659
            In addition to the top slinger, there's also doughnuts welded just inside the axle tubes to help retain the gear oil in the pumpkin and slow it down from running out to the axles. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
