Small Block Oil Baffles - NCRS Discussion Boards
    • 43295
    Many folks think that external oil baffles (i.e. baffles that mount to the main studs rather than those welded into the pan assembly) were only used for 6 quart system oil pans. However, that's not the way it was. There were actually 4 different external baffles used for small block Corvettes over the years.
    GM #3769768. The first was a "flat" baffle plate used for some 1960-61 applications. This baffle was also used for 1963-65 Corvettes with 6 quart oil system as well as some early 1970 LT-1 and all 1970-72 ZR-1. It is pictured in the first photo below. It is designed to work with certain 1960-61 oil pans as well as the 63-65 GM #3820001 and the 1970-72 GM #3956670. This baffle was GM-discontinued in October, 1995.
    GM #3989075. This is one that few folks know about. It was a "shorty" curved baffle plate. It was used for 1970-72 LT-1 with 5 quart systems and all 1973-74 L-82. It is designed to work with the GM #3820000 oil pan. It can be seen in the second photo below. This baffle was GM-discontinued in October, 1982 and can be difficult to find.
    GM #3927136. This is the "long" curved baffle. It was first used for 1968 Z-28 Camaros, having replaced an earlier baffle used for 1967 Z-28 Camaros. It came into Corvette use for the 1975 model year for L-82 engined Corvettes and was used through 1979 for those applications. For 1975-79 Corvettes used the passenger car and Z-28 oil pans. L-48 used the passenger car and L-82 used the Z-28. The pans are identical in external configuration but the Z-28 pan has some additional internal baffling, primarily to accommodate the 3927136 baffle. The Z-28 pan used for 1975-79 is GM #360450. All 1975-79 Corvettes used 5 quart oil systems. The GM #3927136 baffle is still available from GM to this day. It is pictured in the third photo below.
    So, what if you need/want one of the baffles no longer available from GM? Well, the GM #3769768 is available in reproduction. So, that's an easy one. However, the GM #3989075 is no longer available and is not reproduced. No problem, though. All one needs to do is to purchase a GM #3927136, measure 4-1/4" from the end, scribe a line across the baffle at this point, and cut with an abrasive wheel chop saw or band saw. Presto! One has a GM #3989075. If you do this, make sure you de-burr and dress the cut end for safety's sake. A side-by-side photo of the 3989075 and 3927136 is shown in the fourth photo below.
    One more thing: some of you may have noticed I mentioned in my first paragraph that there were FOUR external baffles used for Corvette small blocks, but I only described THREE. So, what about the fourth one? That's for later.
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Small Block Oil Baffles
    Thanks for the thread Joe. I recognize the first one as being what I saw when I dropped the pan on my 63/L-76 about 15 years ago. The "X" stamps are what look familiar.
    Thanks again.
    Stu Fox
    • Clem Z.
      • January 1, 2006
      • 9427
      remember using the incorrect windage tray(baffle) for the oil pan you have can cause a problem with the oil returning to the sump
      • Steven B.
        • June 30, 1982
        • 4021
        Will the 768 fit a '57 pan and function properly?
        Thanks!
        Steve
        • Michael F.
          • June 4, 2009
          • 291
          Can any of these be used be used with the 5 qt C2 oil pan?
            • 43295
            Michael------
            If you're talking about the 5 quart SYSTEM (i.e. 4 quart pan + 1 quart oil filter), the answer is yes. Although it was never used on a C2, the GM #3989075 was designed to work with the GM #3820000 oil pan which was used for most C2 small blocks as well as most 68-74 small blocks.
              • 43295
              Thanks!
              Steve
              Steve-----
              No 1957 Corvette ever originally used an external oil baffle. Plus, there was a "plethora" of different internal baffle configurations used on C1 oil pans. I THINK the GM #3769768 baffle would fit an engine also equipped with the 1957 Corvette oil pan. However, whether it would be a functional improvement or a functional hindrance, I do not know.
                • 43295
                clem-----
                You bet! I agree 100%. That's one of the main reasons I posted this information.
                • Mike E.
                  • February 28, 1975
                  • 5153
                  Joe--
                  The first baffle was also used on 62 340 and 360HP cars, wasn't it?
                  Mike
                  • Tracy C.
                    • July 31, 2003
                    • 2739
                    You gonna tell us about the 12554816 Windage Tray flat oil pan baffle used that was with 1986-1996 Corvette pan P/N 10055765 ???
                    tc
                      • 43295
                      tc
                      Tracy-----
                      No, I wasn't referring to C4 Corvettes. My baffle discussion was intended to be limited to C1, C2, and C3 Corvettes but I should have so-stated.
                        • 43295
                        Originally posted by Mike Ernst (211)
                        Joe--
                        Mike
                        Mike-----
                        I have conflicting information regarding 1962 and that's why I didn't include it. However, I believe that 1962 340 and 360 hp did use the 3769768 baffle.
