1964 differential - NCRS Discussion Boards
1964 differential
  • Jack J.
    • July 31, 2000
    • 640
    1964 differential
    I'm going to have my extremely rusted differential media blasted/cleaned. I would like to remove the vent fitting and plug the hole but am unsure if it's threaded or a press fit. Hopefully it's threaded. Please advise. Thank you.
  • Joel T.
    • April 30, 2005
    • 765
    Re: 1964 differential
    Press fit as I recall... I know the '63 had a metal vent and in subsequent years they went to plastic. I am not sure about the '64... Check the LI Corvette or Paragon catalogs.. You may want to get a replacement just in case.
    Joel
    • Timothy B.
      • April 30, 1983
      • 5186
      Jack,
      If it's metal I believe press fit but not 100%. If it's press and you remove it the squeeze will be lost so just leave it in place IMHO.
      • Gary R.
        • April 1, 1989
        • 1798
        64's used metal and all are press fit. It will pop off with a screwdrive blade under it.
