1961 washer vacuum hose routing - NCRS Discussion Boards
  • Larry S.
    • March 1, 1992
    • 19
    Does anyone know where you connect the main input vacuum hose from engine to the vacuum tank. Does it connect to the upper fitting on the vacuum tanks check valve or does it connect to the bottom fitting? Any help would be greatly appreciated. Larry
  • John F.
    • March 23, 2008
    • 2415
    Re: 1961 washer vacuum hose routing
    The vacuum line from the carb goes to the top port on the vacuum cannister. Is that what you needed?
    John F
    • Larry S.
      • March 1, 1992
      • 19
      Yep, thanks alot.
