Leaking Rear Axle Bearing - NCRS Discussion Boards
  • Daniel K.
    • April 1, 2002
    • 190
    Need to replace a rear bearing/seal. Search provided some wonderful informaion. Any changes to be aware of?
    "Today, replacement bearings for the 58-62 can be either a RW307 series WITH a spacer, OR, the RW607 series WITHOUT a spacer (which is the preferred and EASIER bearing to obtain)."
    and
    "You can always check with Allied Bearing Sales in LA,CA. And if you do contact them, ALWAYS, ALWAYS, ALWAYS ask for the "Corvette club" discount."
    and
    "BEARINGS, seals for: axles, clutch, differential, pinion, transmission, wheels, all years. Olcar Bearing Co, 135 James Creek, Southern Pines, NC 28387, 910-693-3324"
    All from:
    https://www.forums.ncrs.org/showthre...aring&uid=7851
    Thanks again for your help.
  • John F.
    • March 23, 2008
    • 2415
    Re: Leaking Rear Axle Bearing
    Contact Tom Parsons on this forum. He Knows!!!
    • Daniel K.
      • April 1, 2002
      • 190
      Thanks John.
      I will contact him.
      Dan.
