When did Chevrolet change the field coil mounting screws from flat head to phillips, when did the ones for the solenoid change....when did they start using the 1114362 solenoid........Thanks in advance John
Starter / solenoid
Re: Starter / solenoid
John, it had to be after 1966 when they went to phillips head from flat head. Not sure about the solenoid.- Top
Attached Files- Top
What's the best way to get these screws out? They always seem very hard to loosen.
John, I will check my 67 starter but I think the screws are flat head.- Top
John------
If you mean from SLOTTED to phillips, that occurred at the same time as the change from 1107xxx starter part numbers to 1108xxx starter part numbers. So, if a starter is of 1107xxx part number, then it originally used slotted field coil shoe screws. If it's 1108xxx, then it originally used phillips style screws.
I don't know when the change of the solenoid mounting screws occurred.In Appreciation of John Hinckley- Top
