68 Rochester Quad Hunt - NCRS Discussion Boards
  • Jeff P.
    • 799
    I am looking for the correct Rochester carb for my L79. I was talking with Collin Macdonald today, he stated there is a Carb guy in the midwest that has an extensive inventory. Would anyone know this gentleman? Thanks, Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Gary B.
    • July 31, 1979
    • 926
    Re: 68 Rochester Quad Hunt
    Jim McGowan
    Quad Shop
    Rockford, IL
    815-874-4884
    • Jeff P.
      • 799
      Many thanks,Gary
      • Don W.
        • September 30, 1997
        • 492
        Also check Hemmings motor news, they have several people that advertise restored quads. Put your part number into google and see what shows up...Don
        • John D.
          • August 31, 2001
          • 280
          Jeff,
          I believe you are looking for a 7028219 for that application. I spent about 3 years looking for a core. They are rare and expensive. I found one at Chicago Corvette a couple years back. They wanted $600 for a core.
          Best of luck finding one!
          • Michael G.
            • March 2, 2008
            • 485
            If the numbers John has listed are correct, Customrebuiltcarburetors in N.J. is showing it to be IN STOCK. Must call to request price. You can get to their site at name indicated above. Good luck, Mike
            • Terry B.
              • August 31, 1999
              • 607
              Hi Jeff,
              You might have some good luck calling:
              Chris's Carb Shop
              7718 Main St
              Dayton OH 45415
              937-890-0970
              He helped me out and has a large inventory. Good luck.
              Terry Buchanan
              Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
              Corvettes Owned:
              1977 Coupe
              1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
              2003 Electron Blue Coupe
              2019 Torch Red Grand Sport Coupe
              • Jeff P.
                • 799
                You guys are great.Much appreciated for all your help. In looking up past judging sheets my julian code was 3567 . I was once told that this date is on the bottom plate. Is that correct ? Jeff
                  As you search, bear in mind 'QJet' for this era is NOT a single entity... There were two active sources of supply: Rochester and Carter. The stamping and date coding systems used by the two suppliers differed. Details are given in your copy of the Judging Guide book.
                  • Terry B.
                    • August 31, 1999
                    • 607
                    Jeff,
                    I believe, and others will correct me if I'm wrong, the date code on a Q jet carb is at the base plate and is a separate part piece, able to be exchanged easily. So with that said, if you find the correct Q jet carb number, the date plate will not be as difficult to find. Finding the correct numbered Q-jet carb is the trick.
                    Terry Buchanan
                    Corvettes Owned:
                    1977 Coupe
                    • John D.
                      • August 31, 2001
                      • 280
                      Jeff,
                      Yes, I believe Terry is correct the base plate could be changed. Rochester stamping is on the drivers side rear boss of the carb. Date code is on the base plate. Based on your carb date code (about 22nd of December 1967) it looks like you have a 1968 built near the 1st of the 1968 calendar year ??
                      • Dan M.
                        • March 6, 2009
                        • 157
                        Yep. 1968 dated the carb on the base plate edge. I believe 1969 and up dated on the carb body so it makes getting a correct carb date somewhat easier than if it was part of the carb body.
                        Question: Where is a good source for q-jet base plates?
                        • Jeff P.
                          • 799
                          I'm going to check my base plate. I was told by a Chapter judge that I had the wrong carb. Is there still the number 7028219 on the side of a 68 Q Jet carb?
                          • John D.
                            • August 31, 2001
                            • 280
                            As far as I know it should be. Mine has it.
                            • Dan M.
                              • March 6, 2009
                              • 157
                              Jeff
                              YES. It still has the 7000000 series number on the body (in 1968) but without the julian date code. That date was on the base plate in 1968. I believe sometime in 1969 the julian date went just below the carb number, all on the body of the carb. No date then on the base plate.
