66 L79 Distributor - NCRS Discussion Boards
66 L79 Distributor
  • Rich G.
    • August 31, 2002
    • 1403
    66 L79 Distributor
    My 66 327/350 is in for some work. This car is NOT a flight candidate by any means but it does have a correct block and trans and rear, so I don't want to drift any further away.
    My friend is doing the work at his shop and pulled the distributor because I asked him to send it out to be checked because I think it needs it. He told me the band says it's a 300 hp distributor. More than that I do not know.
    What is the difference between the 300 and 350 distributors? Are they 2 completly different units, or can one be made into the other?
    Or should I care?
  • Gary B.
    • February 1, 1997
    • 7053
    66 L79 Distributor
    Rich,
    According to the 66 TIM&JG, the 300HP distributor is GM # 1111153, and possibly 1111117 with A.I.R. and Powerglide. The 350 HP distributor is 1111156 w/o TI and 1111157 with TI.
    Gary
      Re: 66 L79 Distributor
      Or should I care?
      Rich -
      They're identical except for the advance calibration parts - the centrifugal advance weights and springs, the shape of the "football" on top of the mainshaft, and the vacuum advance unit. Doesn't really matter - anyone with a Sun machine (or a dial-back timing light) can replicate the desired centrifugal advance curve.
      • Rich G.
        • August 31, 2002
        • 1403
        Gary
        Thanks. I should have looked in the TM&JG myself.
        John, I was hoping I would hear the answer you gave.
