As part of another thread on judging shocks, there was discussion on the 5 axis criteria for assessing a parts originality. Terry M shared how a judge could access the "date" axis for a service part even when the part was not offically date coded. While I think I understand the concept, I thought I would throw out an example just to see if I have it straight.
In the case of judging the wheel covers on a early 63, the JG states that 63s with a VIN under approximately 2500 should be equipped with frosted covers and also states that these covers will have a thicker perimeter rim.
OK, I have the picture below that depicts the thicker earlier style wheel cover on the left. I also know that there were service replacement wheels covers availlible from GM that were frosted however these covers had the later configuration with the thinner perimeter rim like the cap on the right in the picture below. (scoll down for more)
Ok now for the acid test.
Lets say a 63 with a VIN around 1000 shows up on the judging field with the thin rim service "frosted" wheelcovers. Based on what I've gleaned, I would proceed like this.
Total originality points for wheels cover is 10 points. That is 2 points each for the following
Configuration - The configuration is correct except for the thin rim. Take 1 point
Date - From the configuration I can tell they are the late style service wheel covers. Take 2 points.
Completeness - OK, no deduction
Installation - OK, no deduction
Finish - OK, they are frosted and finished correctly. no deduction.
Proceed to "condition" point accessment.
My real question/point here is that a partial credit can be given to configuration even when it is too late for the application. Is this correct?
thanks,
tc
thanks,
tc
) The later style will appear nearly flush with the edge of the wheel lip and the thicker ones protrude well beyond the edge of the wheel lip. I can try to get some comparitive pics as I have sets of both.
