1990 ZR-1 Bose Radio - NCRS Discussion Boards
  • James C.
    • November 1, 2001
    • 137
    Re: 1990 ZR-1 Bose Radio
    Thanks! That is good advice. Looks like the less expensive way to go also..
    Jim
    • Henry A.
      • May 31, 1990
      • 107
      Jim, I have had the same problem with my 91. I needed to replace the main radio control unit. Can't think of the proper name for it, but it is a box that mounts directly below your control unit for the cruise control. It is under the dash on the passenger side. It is a bugger to take out and replace! I had Ken Andersen at K & B Special Products rebuild mine. Works great now! Call Ken to discuss...770-777-1031.
      I do not think it is the radio or the speaker amps...my guess is the radio control unit. Good Luck.
      Henry Atsma
      54 White/Red
      63 Red/Black SWC
      67 Elkhart Blue/Black BB Roadster
      91 Black/Red ZR1
      96 CE - LT4
      07 Red/Tan
      • Peter M.
        • April 8, 2007
        • 570
        #18
        Try this before you go too much farther on expensive parts and rebuilds:
        • James C.
          • November 1, 2001
          • 137
          #19
          Thanks! I ordered the part and plan to put it in Saturday, if it is not a backbreaker to reach under the dash.. The install diagram looks simple. I hope it works. Thanks again.
          Jim
          • Peter M.
            • April 8, 2007
            • 570
            #20
            Jim
            Let us know if the relay replacement resolves your radio problems.
            • James C.
              • November 1, 2001
              • 137
              #21
              That did it. Thanks for saving me some big $$. It was a little challenging to install for an old timer like me, but well worth the trouble..Thanks again:
              Jim
              • Peter M.
                • April 8, 2007
                • 570
                #22
                Jim
                Great ! I'm glad that it worked out for you.
