Vacuum line connection seal - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    Are there any recommended glues or sealers to help seal and hold the vacuum line connections?
    • 15599
    Re: Vacuum line connection seal
    Rubber cement.
      • 15667
      If you're talking about rubber vacuum hoses connected to nipples, they should hold without any type of glue or sealer. If not, the hose is deteriorated or the wrong size.
      Swabbing the inside of the hose with a Q-tip wetted with silicone spray lube should keep the hose from seizing to the nipple.
        • 6941
        Don, if your talking about the fittings that thread into the carb. or intake manifold, I use a little teflon tape, or pipe thread sealant.
          • 15667
          Threaded vacuum connections usually consist of a flare fitting and B-nut. The seal is at the flare not the nut. If the connection is a pipe thread, then Teflon tape will help.
          The OP needs to describe the exact nature of the connection he's talking about.
            • 3415
            Hi Don,
            I used the original hoses on my 71's restoration.
            I followed a suggestion I first heard from member Chuck Gongloff to cut 1/4" to 3/8" off each end of the hose (if there's enough length) which allows a seal in a fresh area of the hose.
            Terry's use of rubber cement sounds good too.
