58 rear bow strap - NCRS Discussion Boards
58 rear bow strap
  • Brad H.
    • August 12, 2007
    • 724
    58 rear bow strap
    Any body have any pics on the straps that hold the rear bow to the upper bow to snap them together when top is down, have the straps in place but dont know where to fasten snaps on upper piece to bind the two when folding down the top, Thanks, Brad.
  • Brad H.
    • August 12, 2007
    • 724
    Re: 58 rear bow strap
    Hmmmm?
    • Brad H.
      • August 12, 2007
      • 724
      Anybody on board with this? Thank,Brad.
        Brad -
        You should have drilled/tapped holes in the top frame vertical piece behind the window for the snaps. The '57 owner's manual has a photo - don't know about '58 -up.
        • Brad H.
          • August 12, 2007
          • 724
          Yes the 58 also shows this, is that at about the height of the top of the plexiglass window and in the center of the vertical metal?, hard to tell from that small photo. Thanks John, Brad.
          • Bruce B.
            • May 31, 1996
            • 2930
            Brad, see attached pictures.
            The pics are from my 57.
            Hope this helps.
            • Brad H.
              • August 12, 2007
              • 724
              Bruce, so that snap is fastened to the window verticle about 1 1/2 inch down from top of window trim? this must make it so the bow folds up as tight as can be then snaps into place, is this correct? Thanks, Brad.
              • Bruce B.
                • May 31, 1996
                • 2930
                Brad,
                The male snap is located 3/4" below the top edge of the verticle piece and 5/8" in from the inside edge opposite the window weatherstrip. Dimensions are to the center of the hole.
                The snap fastener is a 10-32 by 1/2" long phillips head machine screw.
                Bruce B
                • Brad H.
                  • August 12, 2007
                  • 724
                  Bruce, thanks again, Brad.
