67 rear spring install questions - NCRS Discussion Boards
  • Michael F.
    • 745
    pulled rear differential, spring etc. to recondition. Question is what is proper way to reinstall and torque to mount...do I bolt up torque and then lower put weight back on wheels or tighten lightly and set down on wheels and then apply torque??? thanks, don't want to break ears off diff.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: 67 rear spring install questions
    Michael,
    Tighten the four bolts lightly enough to hold the spring centered and do not torque until the assembly is complete and car weight is on the ground.
    • Larry M.
      • January 1, 1992
      • 2703
      Originally posted by Timothy Barbieri (6542)
      Michael,
      I agree with Tim. Also make certain that the center spring bolt head (bolt that holds the leaves together) is centered in the differential cast/drilled hole and is flush with the differential casting. Some reproduction bolts have heads which are too tall which will cause problems.
      Also make certain that the two spring retaining bolts that thread into blind holes in the differential are the correct length. Too long will crack the differential case, and too short will not provide sufficient threads. Need to check these carefully before torqueing.
      Larry
