I installed a newly rebuilt date correct 68 rochester quadrajet a fue monthes ago. It ran great for several miles. Now it has started to dump fuel in the passenger side primary at idle. It acts like the float is set wrong but only comes out of one primary. I inspected the float level and it was set ok. I also installed a new needle and seat, gaskets, and inside of carb is still nice and clean. Tryed it again and it had no change. I tryed to set the float a bit lower to drop the fuel level in the bowl just to see if it would change anything, no change. Any info on what to check next? Is it possable that there is some kind of small crack in carb itself? Its been a while since I have played with quadrajets, And I never had one flood over on just one side?? My question is, can one thing cause a carb to dump fuel in just one primary?
